Hey guys, I could really use some assistance and advice with this issue.
I have a client who I installed three Netgear Wireless Routers in their home (WGR614v6). The way I have it setup is so that one is acting as the primary gateway (routing and NAT) between the cable modem and the rest of the LAN. This router is also the only one that is running DHCP... and it also hosts a wireless signal.
Connected to this router I have two more routers, same model Netgear, setup on the network only acting as wireless access points, not doing active routing or NAT or DHCP. All of the client machines are attached either wirelessly to one of the three access points, or physically to one of the latter two devices (XBox and printer hooked up physically). I used instructions from Netgear's website to setup the Wireless Routers as "Access Points." HERE is the website with Netgear's instructions, which I followed.
Now for the problems... most of the time everything works well. However, they experience random loss of connectivity where the wireless network will not be available and then somewhere between like 5 to 45-50 minutes later the wireless network will pop back up again. It isn't that the cable modem is having problems, because they would still be able to connect to the wireless network, but not get any internet... No, in Windows it just pops up and reports that the wireless network is unavailable.
I thought maybe the channels were conflicting with other access points in their neighborhood, so I set the three channels to like 2, 6, and 10 (they were at 1, 6 and 11 previously). This didn't make any difference...
The only thing I can think of is this mention of "Potential Issues" from the Netgear instructions I linked above: DHCP configuration may not work reliably because the wireless router/access point may not correctly relay DHCP information from the router. Workaround: Use static IPs on the wireless PCs. The clients get a valid IP address when they connect... but then they lose their connections later... so it doesn't seem like a DHCP issue. I have also made sure that all of the devices with static IPs (the access points, the printer and the XBox) are outside the DHCP range (to avoid IP conflicts).
I am about ready to take these Netgears back from my client and try some Linksys devices. I would just get a router with no wireless, and then two access points that don't know how to do anything other than be access points (ie. non-routers).
What do you guys think!? I am at a loss...
Thanks!
Epsil0n
EDIT: OOohhh, this was my 1000th post! w00t! It took me a long time to hit 1000!
Thanks!
Epsil0n
