BassBomb
Well, I dropped my car, let it settle, got an alignment
According to the alignment results rear camber and toe were dialed into spec exactly (Ingalls Rear Camber/Toe kit)
Front didn't need a camber kit so camber became -0.7 L/R, Caster was a touch higher on left side than right, but still in spec. Toe was apparently dialed into spec.
The problem: Put steering wheel straight when parked, right wheel will look turned to the right slightly compared to left side (which one is closer to straight I can't be certain). So this points to the toe being wrong on some side of the front.
What happens when I drive: Highway especially, I have to turn to the right ~10 degrees to track straight on a the left lane (slopes down to left). If the wheel is put straight I'll go left and die in flames. On a normal residential road the amount I have to turn the wheel to the right is far less but still needs to be turned slightly. Theres no sweet spot that works at all times so its dependant on the road slope mostly.
Tires have maybe 3-5k on them now Falken 912's, I should rotate them.
What should I do and or check? Problem began just after alignment, prior to alignment and the tires my car would pull right at all times (while safer, similar problem). So this is a little confusing
