I recently formatted a Gateway G6-233 PC for a friend of mine (it had 95 on it and was loaded with GPFs from installed/uninstalled software) and installed Windows 98 SE on it.
For the most part, the PC runs fine. I did update the bios to the latest version, and of course downloaded the latest Gateway drivers for the sound, modem, and video card. (I think the video card is a STB velocity 128...yeah, a real screaming card... NOT!)
The problem I'm having is that the monitor seems to go into a sleep state and it never comes back to life! The caps/num lock keys still work, but the monitor never regains the signal. The monitor is a Gateway Trinitron 17".
When I modify the power setting in 98 to never turn off the monitor, I dont have any problems. So, that's a viable workaround.
Anyone have any ideas? (Besides "don't buy a gateway" )If I remember correctly, I think I used the default 98 drivers for the video because the ones I dloaded from gateway said "this is not for the hardware you have" - even though the gateway product number was the correct one.
Thanks!
-Matt
Thanks!
-Matt
