weird problem with AVG anti virus...
Jan 12, 2004
30
i installed the program and whenever i run it to change settings or tinker, it'll close down automatically after 10 or so seconds. for example, it detected i had the worm blaster, i open avg to scan, and it just closes.
i tried reinstalling with no luck.
1sikbITCH
4,194
574
Maybe the worm is killing your AVG. You could try going to Microsoft's website, running the patch that kills the worm, then try AVG again.
I don't know anything about it, just a thought.
Jan 12, 2004
30
yeah i tried getting the patch through microsoft, but now when i try and update, it does the same thing to the download or install wizard.
highly aggravating
Sid59
11,879
my friend had the same problem. he had the gaobot. norton would shut down when i tried to do a scan and it wouldn't even update. i ended up going into safe mode and updating his antivirus and rescanning.
patch your machine
use online scanner
try symantec for the specific virus, usually that have a single download that will search and kill the virus.
xgsound
1,374
8
If you have blaster you have to use task manager(ctrl/alt/delete) to close the running program msblast.exe first to complete any on line task or av operation. Also find and delete msblast wherever you find it.
Jim
Frightcrawler
603
i have a problem with AVG FREE Version too. I tried downloading it multiple times. It did, but when i installed, its name was "RPG World Online." continuing with installation results in installing the game.
anyone else have this problem? its not virus related, because i scanned it using Avast.
Jan 12, 2004
30
ok well i booted in safe mode and ran all the updates.
it was running real well again (well avg still didnt work, but the internet worked well again). i decided to quit last night and continue tomorrow.
avg finds the blaster in "svchost.exe". and well i cant run avg.
ill try and run it in safe mode.
Mem
21,476
13
If it`s the blaster worm.
Manual Removal Instructions
To remove this virus "by hand", follow these steps:
Apply the MS03-039 patch (includes MS03-026 patch)
Terminate the process msblast.exe
Delete the msblast.exe file from your WINDOWS SYSTEM32 directory (typically c:\windows\system32 or c:\winnt\system32)
Edit the registry
Delete the "windows auto update" value from
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\
Windows\CurrentVersion\Run
Link .
