- Feb 18, 2019
- 2
- 0
- 6
Hey guys, I'm needing a bit of advice. I've been having this odd issue after moving. When my washing machine kicks on, my USB hub will power off for a second. I use the hub for my wired keyboard and mouse, so they both power off as well. It's like you just unplugged and plugged in the connector. That's very annoying, especially when gaming. I know washing machines are usually powered by their own breaker, but it seems this one is on the same circuit as my PC. At first I thought this was the issue, however I also noticed that if I turn on the ceiling fan in that room it does the same thing. A fan doesn't pull anywhere near the amperage a washing machine would. So now I'm thinking this has more to do with the electric motor startup.
But this is what really gets me. The USB devices work off the 5V supply. If the 5V supply momentarily dropped enough to kill my hub, wouldn't I notice more issues than that? Wouldn't that power off the logic for the HDDs and other devices on the motherboard? But nothing else quits working, I just have to wait a couple of seconds for my keyboard and mouse to reconnect and I'm good to go. This particular hub has no external power, USB only, and it also has a built-in SD card reader and a blue LED backlight that flickers off when this happens. The only things I have plugged into it are my keyboard and mouse. They keyboard is a Razer Chroma, so it may use a bit more power than a standard keyboard, but nothing crazy.
So now I'm thinking my PSU may be failing. Just before I made this post my PC powered off without warning, then restarted on it's own. That's the first time that's ever happened. I'm thinking the USB issue might be due to the slight voltage dip when the electric motors on my ceiling fan and washer are starting up. Power supplies are supposed to handle those with no issues, but if mine is failing perhaps it can't. Does that sound far fetched? Or do I have deeper issues with my home wiring? Any advice would be greatly appreciated!
