Ok, so my setup is:
Opteron 165 (CCBWE0546MPMW)
DFI SLI-DR Expert
2x1 gig OCZ EL Platinum PC-3200
XFX 7900GT
WD Raptor 74 gig
Seagate Barracuda 7200.9 300 gig
Silverstone Strider (600W Modular PSU)
All in a Thermaltake Armor running XP Pro
Ok, so it all seems good, should work together ok, right? Well, I have been trying to overclock it, but cant get it past 2.43 GHz, and even then its hit and miss whether it will boot at that speed. Im pretty confused, coz this stepping should overclock ok (not more than 2.8GHz, but I was expectimg at least 2.6 from it)
Genie BIOS settings:
270 FSB
9X CPU multi
3X HTT multi
133 RAM divider
RAM is at recommended timings, but lower speed (2-3-2-5 at 1T)
set the CPU voltage to 1.5V (as high as I am prepared to go), and RAM to 2.8v (should be plenty)
So, any ideas? I have heard that you should avoid running fans off the fan headers on this motherboard, can anyone shed more light on that? Any other ideas/ questions?
Update: Ok, set chipset voltage from 1.56 (just above stock) to 1.62. that seems to be helping a lot. I had issues with the CPU fan not always going (CPU was never looking to overheat, but its better now)
Will be going ahead and finishing some isolate then consolidate overclocking tonight, and will update again tomorrow.
DFI SLI-DR Expert
XFX 7900GT
WD Raptor 74 gig
270 FSB
9X CPU multi
3X HTT multi
133 RAM divider
