OK, I have had my system since january. Using the stock cooler I have run it occasionally up to 2.45 GHz (245x10). I installed an xp-90 today and my temps are a little better at stock (5C, probably more if I do a better AS job).
Now however, I began OCing again and ecery time I bring it above 230 HTT, the system either freezes or takes a LONG time to load windows (I restart before it finishes after 3-4 minutes). Is there something I'm missing? My HDD is SATA but I have it in SATA 3 (the non-nvidia one) because I have heard some boards don't lock 1 and 2. Nothing in my system has changed hower (except for the new HSF and vf700 for my video card).
Any ideas or similar experieces. I wanted to try and get a bit higher OC, since I started getting thermally limited with any increase in voltage (>60C @ 1.5 V). Thanks for the help.
