- Sep 28, 2001
- 8,464
- 155
- 106
hi,
i thought this might be interesting. I did some testing running motherboard monitor showing me my case/cpu temps.
I have an enlight 7237 case, XP1800@XP2000....alpha8045 hsf, sunon 80mm fans.
I mounted one sucking fan in the front of the case, and i have one fan in the back, blowing out, in addition to the fan on the cpu/hsf sucking air from the cpu
I opened the case and leaned the case side-part tilted on the side of the case - with huge gaps open, because i thought i might get better cooling this way than with the case side shut tight. (I had some problems with my gfx card overheating)
The funny thing is that i get considerable (3 or 4 degrees) higher temps on case and cpu now with the huge gaps *open* - as soon as i CLOSE the side part of the case i can see the temps dropping like crazy again to normal levels. (I have never seen cpu temps as high as 49/50 before as i did with my case *open*).
It seems as if a closed case provides *considerably* better airflow...the warm cpu air blowing to the side of the case and this heat directly getting sucked out by the fan in the back - and when the case is slightly open this warm air rather seems to be trapped/stuck around the mobo instead of being blown out.
I wonder if i would get even better temps if i close the ventilation grids on the side of the case.....so that there's a straight/undisturbed flow thru the case...hmmm
