BarnyardMonkey
I tried all night last night to get another system of mine up and running through my SMC Barricade Router. (Cable connection)
the Router is the 4-Port Barricade and i had 3 PC's hooked to it till last night.
i tried to hook up the fourth and heres whats happening:
After install of the NIC in the 4th system (Intel 10/100 PCI),i was able to get an IP from DHCP on bootup.
it did load into windows quite slow though.
but when trying to browse the net,it just says "contacting site.........then finally waiting on website reply" then does nothing.goes to "page cannot be displayed".
and if i try to hit Release IP,then Renew... it will just hang and can't get IP. (winipcfg)
but i managed to see other PC's under network neighborhood once or twice,but it will hang when trying to access the other PC's files.
i did however manage to get connected on a LAN game on AOE2 with no problems. (only tested for about 5 mins)
but then if i try to renew IP it will hang then say it couldn't renew,and it still will hang when trying to access other PC's on LAN.
I thought maybe the prob was with my networking cable that i had fixed tonight (50' Cat5),but i tested it on one of the other PC's and it ran fine.
Also know that the NIC in the system is fine.i pulled it straight from my main PC to test it with.
Specs on non working system: (4th PC)
Compaq Presario 5000
Intel 10/100 PCI NIC
50' Cat5 ran into SMC Router (Cat5 was changed over from a Cross-Over cable last night)
Networking Settings:
Client for MS Networks
Intel NIC
TCP/IP
File print sharing (Ident name is different from other PC's)
IE is not set to Auto detect settings
Any help with this would be appreciated.i've never seen nothing like this, i'm lost.
if anymore info is needed just ask and i'll post.
Thanks.
Shawn.
Intel NIC
TCP/IP
Thanks.
Shawn.
