Weird Mobo/ IDE port issue
bradams
247
I recently took an older Biostar Geforce 6100 AM2 rev1.1 out of storage. I plugged everything in and booted it up, and it seemed to be stuck on the biostar start-up screen. I eventually figured out if you wait a minute or two it gets past the start up screen and you can access the bios, or let it load extremely slowly into the next startup phase. Interestingly, when I disconnect the IDE hard drive it loads up fast and fine. I tried using a SATA hard drive and that worked great too. Then I thought it might be the IDE port, so I tried switching to IDE2, no luck. Then I tried a different IDE hard drive, same thing. Then I tried a different IDE cable, same thing. Is there something I'm missing here? It's like its not properly compatible with IDE devices.
bwatson283
1,062
if your bios has "load optimized defaults" or load "fail safe defaults" try doing that. Or if you feel up to it, try flashing it.
