Weird... I am not sure which GPU cooler I have...
deadken
3,199
On 09/04/2006, I bought a Arctic Cooler Accelero X2 from Newegg. I had a X1900XTX at the time and the fan noise was just too much for me. So, I get the cooler and mount it to the card. I use it, then get rid of the X1900 XTX for a 8800GTS, but I kept the Arctic Cooler (I put back on the stock cooler).
Fast forward... I still have my 8800GTS and am still happy with it. I bought my son a X1650 Pro card for his PC. It was only $26 new (after M.I.R. and Google Check Out). Unfortunately, they sent me a 512MB card that only did 500 Core and 270/540 Memory rather then the 600 Core and the 800 Memory that it should have. I RMA'd the card and I should get it back tomorrow. I picked up an inexpensive 8600GT, that is still sealed up in the box. Just to have on hand if I am still unhappy with the X1650 Pro. If I have to, I'll RMA it again or just sell it off. Either way, and my son gets the PNY 256MB 8600GT.
I got to wondering if I could use the Accelero X2 with either of these cards. I knew that there were 2 revisions and it looks like I got the NVidia one shipped in the ATI package. When I looked up my previous orders on Newegg (dang, I shopped there a lot!), I found the link to the cooler I bought, BUT the pictures for that card don't match the cooler that I had. Here is the link to the Cooler that I bought: Deactivated Item
In that link, the back of the cooler looks like THIS. I do remember being surprised that the ATI X1900 XTX stock cooler had a slightly different set of holes then the Arctic Cooler, IIRC, it was only one hole, so I didn't really consider it a problem. The Core was certainly mounted securely and the memory chips made contact with all of the pads very well. If you look at the first picture of that cooler (all the way on the left), you will see a slight bump (down in the corner where the 'X2' part of the label is). That bump is there in the first and fourth photos, but not in any of the other photos.
THIS is what the back of my Cooler looks like (except mine has my memory heat pads still stuck on it) and I certainly did not get a 'back plate' included in my kit. The weird thing is that the little 'bump' is only visible in the fourth photo and none of the others. Perhaps I should mention that my cooler does have that little rectangle hole in the end of it over where the heat pipes end. One of the coolers has that, the other doesn't.
BTW: I fell asleep in front of the keyboard last night. I am sending this off without proof-reading or even checking if the links work right. Sorry for any errors, I'll check it after I get back from work (I've been late to work too many times when I sit in front of the PC in the morning)!
potato28
8,964
Could you take actual pictures of the cooler itself and post the links? I might be able to help, I do have the X2 on my x1900gt so I know what it looks like.
deadken
3,199
Front
Those pictures are of my actual GPU Cooler. You can see where the package states:
Compatible with:
ATI X1800 series
ATI X1900 series
Wouldn't you know that Diamond MultiMedia entered the wrong ZIP Code on my package and now UPS couldn't deliver it today! I called UPS and they said that the address was already corrected. They said that the package was still on the truck and might be delivered tonight. Otherwise, I might end up driving to the 'UPS center' and picking the package up myself tonight. I don't want to wait until Monday to get this card back.
I am really wondering if the four screws on the copper section of the cooler will line up with the four screws around the X1650 Core. If that is the case, then I will have to see if the Cooler can be mounted without interfering with any components on the card and without intefering with the PCI-e slot. If all works out, I will order some more Memory pads and clean off the old ones. I might get some use out of this yet.
If I can identify this cooler, I can at least sell it and then put the money towards another cooler.
potato28
8,964
Looks like it will only fit on the x1800 through x1900 series. Unless you wanted to remachine it for the x1650, all I can think of is to try and sell it for a half decent price.
deadken
3,199
So, that is the same X2 as yours? Does yours have that little 'bump'? I want to make sure that if I list it as an Accelero X2 (which is what I bought it as), that it really is.
Thanks for your help, Ken
