weird front panel connection....
Intexity
299
ok so i know i should know this, but am used to the front panel being a single block to connect to computer, not seperate wires.
here is how they come out of the case (some free case don't know what kind)
Ground-gray wire (simple enough)
mic in-red
micpower-black
this is where it gets weird
l-out with an extra daisy chained plug titled l-out
r-out with an extra daisy chained plug titled r-return
i also have two wires that i believe to be to the two usb plugs in the front labeled
-d white
+d green
+5v brown
ground yellow
four pins per usb connection??? uh oh i think im lost...luckily the standard power connections are exactly that-standard...
anyways im connecting an MSI g31tm-p21
JAUD1-
10-headphone detection 9-headphone l
8- no pin 7-SENSE_SEND
6- mic detection 5-Headphone R
4- presence 3-Mic R
2- ground 1-Mic L
JUSB1/2
10- Reserved 9. No Pin
8- Ground 7- Ground
6- USB1+ 5- USB0+
4- USB1- 3- USB0-
2-VCC 1-VCC
please help before i decide to get creative and rip the usb and front panel connections off another case and make them fit on this one. thank you for your time...
Intexity
299
ok got the usb figured out - four pins per side vcc = +5v wire yada yada yada... so hopefully once i finish this the usb will work, but am still confused on the front audio connections...please help
mpilchfamily
3,559
Here is the USB info you need.
http://www.machspeed.com/tech/fpusbsupport.htm
For the Audio you'll want the Headphone L and R to go to the L and R out. Don't worry about the daisy chained ones. The mic in and Mic power need to go to mic L and R. Try it one way then test it and if it doesn't work try it the other way. Course the grey ground goes to the ground pin. The otehr pins are not supported by your case and not needed.
Intexity
299
thanks once again...
sent you a pm mpilch
awesome searched like crazy and couldnt find that. you rock!
mpilchfamily
3,559
I used google search to find the USB for you. Figured i had to find a USB internal connector that was split up. So i used the Image search.
Intexity
299
USB is working the front audio jacks are not but oh well not going to worry about it. just have to use the rear jacks for my headset. thanks to all
