Hey fellas I have a totally screwed up MS Excel problem and I hope someone has some sort of idea how to fix it.
Symptoms:
-- Whenever I use Excel after about 5 mins (sometimes more or less) my computer gets super slow, almost to the point of lockups. The mouse and the keyboard both lag and hesitate as I try to do anything. It will often repeat keystrokes due to this hesitation.
The machine stays in this state until reboot which is the only way to fix it. Simply exiting Excel does not make the problem go away.
This only occurs with Excel.
It also makes no difference what I am doing or have running on the machine (ie other programs open).
System is an AMD X2 3800+, 2gb of Ram, 160gb HDD (using about 30gb)
Running Windows XP Pro, NOD32 AV, No Windows Security Center
I have AV Scan, AD-aware scanned, Spybot scanned, and defrag many times and this problem will not go away.
Hoping someone here has a solution as this is a MAJOR issue for me (I'm an accountant and use excel all day).
Thanks in advance.
Greg
Symptoms:
Thanks in advance.
Greg
