I have an Asus A8V, with an Athlon64 2000+ and two sticks of Corsair VS512MB400 . After noticing more instability than I'd expect, I decided to run Memtest to check the RAM. Using memtest86+ v1.70 from a CD I checked each stick of RAM separately, and after a few a hours of testing each, neither returned any errors.
However, when I put both sticks in, Memtest shows repeated errors on test #5. I have the sticks in the appropriate banks (DIMM_A1 and DIMM_B1) and the BIOS is set to defaults. This RAM is specifically listed as compatible in the A8V manual, and I don't think I've changed any jumper settings.
Anyone have a clue what the problem is? I'm tempted to RMA the memory, but since each passes memtest separately, I'm not so sure that is the problem.
Any help would be appreciated! I'm quite confused : /
