EarthwormJim
All of a sudden today, I turned on my computer and I had no display. Restarted my computer and turned on my tv and noticed Vista all of a sudden was defaulting to my TV-Out on my 8800gt as the main monitor.
Thought it was weird, so I tried to make my monitor the main display, it wasn't even detected. Unplugged the monitor and switched DVI outputs and it was detected. Set it as the main display, but now I'm limited to 1024x768 resolution. Can't go any higher even though my monitor's native resolution is 1920x1200.
Thought a restart would fix it, no luck. The monitor wasn't even detected on restart, and Vista again defaulted to my TV-out. Tried to restart again without the tv plugged in, no luck, no image at all.
Tried system restore, still now luck.
I reinstalled my video drivers, tried deleting the monitor driver when it was detected (after unplugging then replugging it in).
Finally tried safe mode, everything works normally there.
I'm really out of ideas though, I can't use my computer only in safe mode, and this resolution is rather annoying.
Thought posting here would be best, cause the monitor works fine when my computer is booting up, but not after Vista has loaded (OS issue...).
