AllGamer
Core 2 Duo E6400
ASUS P5VDC-MX
During installation everything was fine, no complains no thing.
After a night out in the back of the card (freezing temp), and powering up the machine at the clients office.
Everytime this thing boots up complains about FAN error, press F1 to continue.
Very well, go into BIOS and see FAN spining around 800~900 RPM
you let it boot to WinXP, everything works fine, restart the computer, and no more complains, check BIOS, FAN spining at 8000+ RPM (around 8600~8900+)
and it works fine for the rest of the day, but if you turn it off, then turn it back on the next morning, **** thing does the same FAN - F1 error message again?...
What gives?
there's nothing phsycally wrong with either fan or mobo, or the power.
is only during the 1st power up of the day, that does that weird thing, when everything is Cold (room temperature) that's around 15c
Yet it never complained when it was in my place during install (room temp around 20c)
is the morning air too cold for the CPU FAN?
This is the Retail boxed FAN that came with the Core Duo
The fan is plugged to the ASUS mobo into the CPU Fan plug.
What could be wrong with this thing? the Mobo? the Fan? the PSU?
but if it's any of the above then the problem should happen all the time, not just during the 1st boot of the day. :frown:
ASUS P5VDC-MX
What gives?
