Weird clicking noise from hard drive
bullion416
658
I just got a brand new Maxtor 60 gig hard drive (Model: 6Y060L0) I actually got this as a replacement drive from Maxtor because my old drive was broken. The one they sent me is a newer model (not refurbished....it is actually a new hard drive)...........well, every once in a while when the hard drive is searching for info stored on it............I will hear a short clicking noise.......It won't last long and doesn't seem to affect the way the computer runs. Do you think this is normal or do I have another bad hard drive?
BlueWeasel
15,944
475
I have that exact same Maxtor HD running in my system, and I have not noticed any "clicking".
Is it a random occurance, and if not, specifically when does it happen? I'll be listening and let you know if anything comes up...
ddasilva99
33
Any click click click or tick is a HD ready to fail. I would have someone look into it immediately and start backup!
bullion416
658
Could this problem be a result of updating to windows xp service pack 1 or even updating the VIA drivers for the motherboard? I ask this because I didn't notice this click noise before I updated these drivers.
BlueWeasel
15,944
475
I doubt its related to the XP SP1 or even the VIA drivers. Any "clicking" noise from a HD is likely a hardware issue.
If its a mission-critical drive, then you may want to consider RMA'ing the drive again. I probably would just make sure my important data is backed up and see how it goes...
Johnny101
69
Yup exactly right. Back this up ASAP, the end is near for that drive.
tenoc
1,270
Why not run the utilities since Maxtor will probably ask you for the resulting fault code before they issue a RMA anyway.
bullion416
658
I have not found that program to ever be of help. It usually doesn't detect physical issues with the drive (i.e. the clicking noise). I have sent back 2 drives to maxtor without a trouble code. They have been very understanding. In fact, they appologized for the problem with the replacement drive they sent me. I think it was a shipping problem because when I got the box, it was dented in. They are even paying for me shipping of the old drive back to them. Thanks for all your advice
