- Mar 2, 2005
- 1,834
- 0
- 0
I recently had a asus a7v266 mobo with amd athlon xp 1.8ghz 2200 processor that occasionally on startup had a very loud buzzing sound coming from who knows where in my computer. Upon restarting I would be in my bios with a msg saying that my system ran at an improper cpu speed and the setting would show my cpu speed underclocked to 1.3ghz. After resetting it back to the proper speed it would work fine. I then recently changed my mobo to dfi lanparty ut nf3 with amd athlon 64 3000 to see if this would fix this problem and also since I had a sata drive sitting around anyway. But again I would get that weird buzzing sound but upon restarting it would start normally instead of going into bios. But the buzzing would happen a lot more frequently that before. Is there anything I can do to fix this? Should I change my power supply?
p.s. I also notice the buzzing would usually happen when I start the computer after I played WoW for an extensive period of time the previous session.
