Hi all,
I have a strange problem. I have 2 IDE drives, a maxtor and a western digital, in my machine. The WD is a secondary drive, so I wanted to disconnect it to hook up my GF's old drive. When I disconnect the drive, OR change the drives to ANY other configuration, the computer wont boot. I get "NTLDR is missing" errors, "boot disk no found", etc. The ONLY way it works, is to select the boot drive after the Bios posts, and then select the WESTERN DIGITAL, THE SECONDARY DRIVE???? And then the computer boots fine! The other weird thing, was that when I originally installed the drives, my primarry came up as the D: drive, and my secondary as the C: (its still like that). I also have a SATA drive, but that is secondary, and doesn't seem to interfering with anything. In the bios, the drives show up normally, and I've double checked the jumper settings on the drive, as well as tried new IDE cables, and switch their positions. I even tried putting the WD on the channel that has my dvd burner and that didn't work. Any ideas??????
Thanks in advance, John
