Weird Blue Screen in Win2k need help interpreting!!
JorgeElPrimero
240
Here is the exact message that I am getting.
*** STOP: 0x0000000A (0x00000000, 0x00000002, 0x00000001, 0x80068349)
IRGL_NOT_LESS_OR_EQUAL
*** Address 80068349 base at 80062000, DATESTAMP 381f8c6e - hal.dll
Beginning dump of physical memory.
Physical memory dump complete.
Contact system admin... blah blah
Ok I am pretty sure this is a hardware problem. I was having this problem under win2k and decided to reinstall thinking it would fix it. Now win2k won't even finish installation without this problem occuring.
The first time I had this installed on the 46 gig IBM deskstar 75gxp. The second time I tried installing it on the 60 gig IBM deskstar 60gxp.
The error occured when I was installing something or moving files. Please help.
slpaulson
4,414
14
Hmmm you do have the latest via 4 in 1s installed right? Or the latest bios? I see you have a live! soundcard.
MortaniuS
654
hal.dll is crashing you. find teh source. Look under device manager, VIEW " Show hidden devices" and try disabling it.
Jesta
346
I used to have a similar IRQ message when installing Nt4 from cdrom, when I did it from floppy it worked like a charm. Although there should be no differences that's my experience.
