So today during a brief outage from my Cox cable, I heard an awful humming noise coming from the TV. I also noticed (due to a pure black screen) very light horizontal bars moving slowly up the TV. I have a 32 inch LCD HDTV and a Cox set top box. Normally I can't hear it because there's other sounds coming from whatever's on, but the hum is still there and I can hear it if I turn up the TV loud at all, and the rolling bars are definitely noticeable.
I googled this stuff and everything seems to point to something called a ground loop feedback, or something. Basically there's a bad ground somewhere. So I've done about 3 hours of troubleshooting and come up with the following info:
#1. The humming disappears if I unplug either the Coax cable from the set top box, or the Green component cable from either the set top box or the TV.
#2. The humming disappears if I only plug in, say, a DVD player. With either component or composite cables, as long as whatever box I'm plugging into the TV doesn't have a Coax cable running into it, there's no hum.
#3. The humming happens whether I have my digital cable set top box plugged in, or a VCR, so long as a Coax cable is running through the box.
#4. I've tried switching electrical outlets, plugging it into a surge protector, plugging it into a different Coax outlet in the wall upstairs, and none of those do anything, the humming/bars continue.
#5. If I plug the coax line directly in the TV, there's no humming.
So what the hell is it? I feel like I've elimated everything it possibly could be. It's not the cables, because they work fine if plugged into my DVD player. It's not the electrical because there's no humming if I'm using a DVD player or like, my N64. It's not the Coax cable because it works fine when plugged directly into the damn TV. It's not the set top box because the same thing is happening with a VCR.
Someone help me, please!
