Originally posted by: platinumike
Originally posted by: F22 Raptor
Intensity you do not have to worry about, just make sure you give yourself enough time to recover.
As for the failure thing, it depends on what type of program you want to do and what your goals are.
My goal is to just get big and muscular, Im eating alot, and trying to gain weight. Tone is good but I know I have to get big first before I get tone.[/q]
That is one of the biggest misconceptions there is. Lets stop for a minute and think about this. I'm trying to gain "weight" (what kind of weight? Fat? Muscle?) go back to my earlier post and read what I said about this "Blanket statment" that people use when they get into working out. You do NOT want to gain WEIGHT. You want to gain LEAN MASS , or MUSCLE. You don't just put on a bunch of weight and turn it into muscle....Fat does not turn into muscle , much to the chagrin to the overweight people out there. You BUILD MUSCLE TISSUE THROUGH DIET , AND EXERCISE , AND REST.
you need to identify your goals. Do you want to be a big guy for your size. Or do you want to be defined. with a balanced phisique?
It sounds to me like the later , you want to be bigger , but you want it to be "defined" chisled , balanced.
This requires a balanced diet. A good start is your protein / carb intake. If you want to get the most growth as soon as possible. (and you need to do more homework , because I'm not going to go into everything!!) A good point to put in your head , is that you need 2 grams of protein for every pound of bodyweight you weigh. EVERY DAY. In order to adequately have enough available proteins and amino acids for your body to Generate , and repair damaged muscle tissue. If you are working out hard , and not getting enough. The first thing your body will burn up is the hard earned muscle for fuel. It's metabolized faster than fat. You need to keep the muscle you have , and add more.
Here is a litte tid bit fact.
For your body to maintain 1 lb. of fat , it only needs 1 calorie per hour to keep it.
For your body to maintain 1 lb. of muscle it needs 50 calories per hour to keep it.
By adding 10 lbs of muscle to your frame , you are increasing your bodies metabolic rate by 500 more calories. IE. your body will be burning more calories just sitting around. Which will help you to lose any of that other fat you are trying to lose. But that is where diet will make or break you.
