Originally posted by: SirChadwick
diet is #1 - try consuming only about 1500-1750 cals per day (more or less depending on your total weight)
also make sure that you're eating whole foods, no preservatives, too much sugar, etc. - just be smart. Drink only water/juice/milk.
exercise #2 - running 3 miles a day is fine for the average person, but what you probably need to do is shock your body. Try HIIT for a few weeks and see what your results are. Also mix up some weightlifting with your workouts to burn muscle while you sleep.
Originally posted by: Amused
I strongly advise AGAINST intentional calorie deprivation... unless you want to end up fatter in the long run.
Simply clean up your diet and add an extra day of exercise. You may even want to add weight training to your exercise routine.
Originally posted by: 3cho
weight training is out since i am moving soon and i dont want to sign up for a membership. i weigh 155 right now and would like to go down to 140. i am not ashamed to say it, but i have got love handles and they have got to go. so may crunches as well?
as long as he doesn't drop below 1200 a day he'll be fine
there is no such thing as spot reduction. just have to burn the fat away.
1200 a day? Argh, that's for Hilton and Lohan.
What he said. Don't make it worse by not eating enough.Originally posted by: Amused
Every person needs different exercise regimes due to individual body-types to get maximum results. What is your weight/height/age, etc?
Originally posted by: dullard
There are temporary weight loss strategies and there are permanent weight loss strategies. Almost everyone who diets only tries the temporary ones. Why? Because they promise and often deliver nearly overnight noticible differences in weight. But of course, this quick weight drop is followed by even bigger weight gains down the line because most diets are just temporary bandaids on the bigger problem. If this is what you want, just about any diet works. Atkins is surprisingly quick and strong for a temporary weight loss diet (Atkins, like most diets typically isn't permanent).
For a permantent weight loss, you need to find out what YOU honestly and realistically can do for life. The answer to that question will vary from person to person. The only way to lose weight is to have less mass enter your body than exits your body. Eating less will work. But decades of failed diets will show you that simply eating less is not permanent - almost no one can stay on that diet.
Studies have shown again and again that the one way that most people can lose weight and keep it off is to work on the opposite end of the bolded section above. Realistically, people can't stop themselves from overeating. So don't fool yourself into thinking you can do it permanently. Instead, train your body to just dump that overeating into the toilet. Add fiber to your diet, and you'll probably find a permanent and significant weight loss.
No, fiber doesn't allow you to eat anything you want. You still have to have some self-restraint. But fiber will allow you to eat like you normally want to eat and still lose weight. To date, no study has shown ANY diet which has more weight loss long-term.
also, i am starting a job that is likely to be extremely stressful and extremely long in hrs (~90-100hr/week). what are some things that i can do?
I venture to say that probably 99.9% of anything ever said about metabolism is false. Just don't listen to anything about it. Ignore metabolism, it is just a modern day snake oil.Originally posted by: JohnCU
it's not always as simple as calories in - calories burned etc since some foods/drinks increase metabolism. way too many variables.
like alcohol, 69 cals per oz of scotch, vodka, etc but alcohol speeds up metabolism.
