Weider Total Body Works 5000: $129.99+tax
Status
Not open for further replies.
Pardus
8,197
21
$129.99+tax@walmart.com
Improved resistance system
Resistance bands increase weight resistance beyond the users own body weight
Adjustable incline bench on wheels with a pulley on each side
Turns your body weight into natural resistance and provides the option to increase weight resistance up to 50-pounds with the addition of the four resistance bands
Adjust the bench to a steeper incline to increase the amount of weight resistance
Cable and pulley system allow for greater versatility and greater range of motion
Exercise machine provides a variety of exercises that strengthen muscle and increase flexibility
Weider Total Body Works 5000 includes workout guide with over 100 body-shaping exercises
Some assembly required
Exercise machine dimensions: 71" L x 26.5" W x 49.5" H
As Seen On TV
donfm
677
Looks like a knock off of the Total Gym which is much better quality than Weider but at a higher price as well....:)
donfm
677
solid reviews...does anyone know if this can be used in a condo w/ hard wood floors?
I find it curious how most of the people have this for less than a week and write a glowing 5 star evaluation. That's just insane with a piece of exercise equipment.
From experience you can't put any exercise equipment directly on a wood floor or you're asking for trouble. Either put it on a rubber mat or a rug with a rubber backing.
Apr 17, 2003
37,622
yeah, I was going to put a mat on but I'm not sure if this makes a lot of noise...doesn't appear to though.
Pardus
8,197
21
can anyone give me a reason not to get it, looking to get rid of the expensive gym membership.
daveybrat
5,805
1,018
No reason not to get it. Pick up this, some cheap dumbbells as well at Walmart and you're good to go.
I picked up some Gold's Gym Dumbbells for cheap there that are very good quality and they were about $20 a kit (bought 2).
Gym membership fees lately are just too much for me. Cheapest around here is between $30-$50 a month....no thanks!
Mongoloid
I've had this for the past year. It has done it's job strengthening my upper body to the point where I can now do my own pull-ups, dips and pushups as my exercise routine. So after a year, I use it hardly ever. Sad to say but before the weider, I couldn't do one pullup or more than a couple of dips. My only knock on the unit is that the bench does not slide smoothly on the track. It is not ball-bearing or anything like that--just rubber wheels.
btw, got mine from amazon where it has been about the same price for the past year or two.
Status
