Website Help (Lightscribe)
Status
Not open for further replies.
Nik
16,101
Probably a browser rendering issue. Are you using Chrome or Opera? Try it in IE or FF. They work just fine for me. You shouldn't have to scroll anywhere for the popup. There's a little box that appears right over the CD. In theory, it's supposed to pop up under your mouse.
austin316
3,572
ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhh, using my widescreen monitor is what is causing it. Got it now.
eplebnista
24,123
36
thanks for posting the solution. :beer:
austin316
3,572
you're welcome. (unless you were being sarcastic). also, you don't need to change the resolution on your monitor or anything. just make the web browser window in a squarish (4:3) shape.
Status
