- Aug 17, 2009
- 5,195
- 1
- 71
Probably stock piling these to counter 6870. The problem is GTX480 runs pretty hot. So a 512 SP version will consume even more power. I would have much rather seen a 384 SP GF104 clocked at 850-925 mhz to replace the GTX470.
The only reason I doubt the article is because nV would not keep the same name...it would be a 485 or "485 512" in my opinion.
Two 8 pin plugs? I wonder if they will upgrade the cooling for this 300 watt card.
However, I think you are basing your assumption off the immature version that nV was forced to rush out to stop the bleeding.
I doubt that Nvidia has made any significant revisions to the GF100 since its launched. Don't they write stepping codes on their gpus. Was the GF100 launch product using A3? If they had newer steppings, we would likely see some cards using them already for sale (even if they aren't 512 shader enabled).
any photos showing that or just speculation?
They probably tried a lot of times (way more than 3). Makes sense that the next stepping will have a different name but it could be like RussianSensation suggested, that they were yielding 512 shader parts for a while already and they were being stockpiled.
Bogus. Texture fill rates are the same in both screenshots. Shouldn't the 512 sp 64 texture unit increase texture fill rates?
I was thinking more along the lines of a gtx280 to gtx285 without the shrink.
A respin could get them better thermals ,higher clocks and less leakage.
A much better all around cheap.
Wishfull thinking probrobly, but definitly possible.
I'm thinking that if they had better than A3 silicon product, it would likely be for sale in some of the current GTX 480.
__________________
It does. Probably unsupported by GPU-Z. Look at the results of the Vantage feature test 1 (filtrate). The 480 scores 38.82 GTEXELS/S and the 512 scores 41.55 GTEXELS/S. Sooner this is out the better, I'm itching for an upgrade.
I'm thinking mabe they needed to respin to get the performance they wanted.
Why release it if it isn't at least 15 percent faster then the gtx480. This is why I believe it will also sport higher clocks with more sp's and be more overclockable.
