Web site design help please!
Turkey
Hi,
I'm helping to build a small to medium size database driven site and we want to create a site map before we start coding. Are there any tools out there that would be recommended for just creating a conceptual site map, ie what pages will be in the site, drawing what links are between pages, etc?
Thanks!
If by any chance the database-driven site is going to be done in ASP, I would assume you are using Vis. Interdev then. If so, once you created new project, in project explorer right-click on the project name, choose "Add", and then "Site Diagram". The wizard will take you from there 🙂
Good luck
<< If by any chance the database-driven site is going to be done in ASP, I would assume you are using Vis. Interdev then. If so, once you created new project, in project explorer right-click on the project name, choose "Add", and then "Site Diagram". The wizard will take you from there >>
Just what I was looking for! Thanks!
