Web page advice
Double Trouble
103
I have a page that was built using tables for the layout. Working with table layouts and such seems very messy and clumsy to me, I'd like to recreate the page (or something similar) using div's / style sheets. Unfortunately, my skills when it comes to using div's / style sheets (or nice graphics design) are pretty much non-existent.
If one of you has web page design skills and is willing to spend a few minutes looking at the page and how to recreate it (or something like it), drop me a PM.
Thanks!
Tweak155
11,449
264
I've done this myself a few times. Sometimes tables are just the easiest thing to use, but 9 times out of 10 DIV's are the way to go.
Leros
21,867
7
It wouldn't be too hard for you to learn basic CSS/HTML. I've started doing some web frontend stuff at work and I had to learn basic CSS/HTML with absolutely zero previous experience. It's really not that hard to do basic layout and design (although the artsy/designer "making it look good" part requires skills).
Google for "css div layout".
the182guy
27
Agree with above, google for pure CSS layouts. It's not that hard to pickup the basics, plus there are loads of examples out there. If you're looking for a CSS book, I recommend "CSS Mastery".
Ken g6
Moderator
Dec 11, 1999
16,838
4,817
75
[thread=2194250]We just went over this[/thread].
But, then again, that was "NOT for beginners." I turned up this page, which looks silly, but gets the message across clearly.
Bulldog13
1,655
Thanks!
If you have already built it with tables, your best bet to recreate it with CSS and div's is to use a CSS grid system. They don't take that long to figure out and layout is very very easy.
I recommend http://www.blueprintcss.org/, but there are a bunch out there.
Essentially, you decorate your divs with different classes and they move around the "grid".
http://www.blueprintcss.org/tests/parts/grid.html
