- Jan 8, 2022
- 3
- 0
- 6
I've recently discovered a big issue between running a speed test via web based applications and local (downloaded) applications. I've tested many brands and have come up with the same results but I will focus on Ookla for this post.
When I run the tests online I get between 100 Mbps and 200 Mbps. But when I run the downloaded applications I easily get over 800 Mbps. I am paying for the 800 Mbps Xfinity (Comcast) plan.
I have tried different browsers as well as adjusting throttling speeds in Chrome. No matter what I do, I continue to get sub 200 Mbps with online speed testers.
I also tried resetting my TCP/IP settings with the following commands:
Attached are my Ookla screen shots for the web based and local applications. You can also see that I used the same server as well (Baltimore, MD Comcast).
Can anyone explain this to me?
My setup:
Comcast Cable
Arris G36 Gateway
TP-LINK 24 port gigabit Ethernet unmanaged switch
Trendnet 16 port unshielded patch panel
Cat 6 cable
Both computers are connected via ethernet
All tests completed via ethernet connect only
- Type netsh winsock reset and press Enter.
- Type netsh int ip reset and press Enter.
- Type ipconfig /release and press Enter.
- Type ipconfig /renew and press Enter.
- Type ipconfig /flushdns and press Enter.
My setup:
Comcast Cable
Arris G36 Gateway
Cat 6 cable
