Web application people: please help!
dmurray14
1,780
Hokay,
I have a database driven web page that is returning a list of inventory from the database after a search. Next to every entry in the list is a modify button that makes a javascript popup window with a form to modify the contents. After a user clicks submit, the page posts the data to another page which performs a query to update the database, then javascript closes the popup window. What I need to do is make it so that when the popup window closes, it refreshes the original page with the list of inventory. I also want it to reload using the previous data it posted to that page (ie if I were to press refresh on the inventory list page it would ask if i wanted to use the previous data that was sent with the page and I would have to click retry). Any ideas on how to get this to work?
Thanks,
Dan
dighn
22,820
4
Originally posted by: dmurray14
Hokay,
Thanks,
Dan
sounds like how this forum works. look in the html source?
torpid
11,631
11
don't understand the last part, but you can do window.opener.{whatever the function is to reload which I've forgotten - location.refresh?} from the pop-up before you close it.
