- Feb 1, 2001
- 6,135
- 2
- 0
So I've always had sporadic connectivity issues in my basement (which is my primary location for using the laptop) and I've finally reached the point of frustration that it's time to do something about it. Check my game plan and let me know what you think.
I live in a townhouse that's about 20x40, wireless router is in the office/spare bedroom at the front of the house with my main pc. Couch/big screen/etc in the basement is at the rear of the house 2 floors down so it's pretty much the longest possible run between the walls. My connection shifts from full strength to zero, back to full, nothing for a minute or so, full strength, etc...very frustrating. I have a 2.4Ghz phone w a base station in the office a good 8 feet away from the router. Antennas are oriented at 9 and 3 o'clock in (what I thought was) an effort to increase signal strength to the lower floors. Running a WRT54G v2 that I recently flashed to DD-WRT and increased the signal strength on (which appears to have made no difference whatsoever). Moving the cable modem/router to the middle floor is not an option as I don't want to run the main pc on wireless. I'm contemplating 3 options here:
1. Pay someone to run cat6 from the spare bedroom, probably through the attic, probably down one of the air ducts and into the small room w the hot water heater/heater/etc (or get it down in the basement some other way). From there install another access point (or move the existing). None of the 3 closets in the basement have outlets so one will need to be installed. Cost probably a couple hundred.
2. Install new antennas on the router. Found these on ebay for around $21 w shipping...7db boost. Suggestions on something better are welcome.
3. Install a wireless repeater someone on the main floor. I get pretty decent signal here and if the repeater will actually do what it's supposed to that's great. I'm aware they can cut speed, I don't do any wireless gaming or heavy file transfers from the laptop so as long as my connection to the rest of the world is the bottleneck I'm fine w it. Probably go w the WRE54G unless someone has a better suggestion. Cost ~$70
Cost is a concern, op1 is definitely the most expensive followed by 3 and then 2. I'm just concerned that #2 won't get the job done and will be money wasted so I'm pretty much stuck between those two options.
So whaddya think? 3? 2? 1?
Cliffs:
wireless signal drops
read the options
whaddy think?
Cliffs:
read the options
whaddy think?
