- Nov 11, 2008
- 3,204
- 52
- 91
I caught a dirt cheap ECS A970M-A Deluxe motherboard ($19.99 with a $30 MIR I'm still waiting on) last winter and but an FX-6300 in it. Its really fine at stock, but it simply can't OC beyond 4.0 Ghz. Any multiplier higher than x20 won't boot. It also won't boot if I adjust the voltage at all. I was able to get it to 4.4 Ghz using a 220 setting for the FSB in conjunction with the x20 multiplier. Its stable enough at these settings - ran Prime95 for an hour and gamed extensively with it. Stays cool too.
My question is, should I replace the board with something better for overclocking? I know the FX-6300 is capable - I tried autotune with AMD Overdrive and it went to 4.6 Ghz just using that software (x23 multiplier). I just wonder if an extra 200-400 Mhz would be worth spending the money on (as far as noticeable performance).
Should I go the replacement route, what would be the most capable overclocker for the least amount of money (chipset doesn't matter - will only use a single GPU)? I'm willing to go up to $150 if necessary.
