I've built several systems and setup several new HDs, but I'm stumped on this one.
Just received a new WD800JB (80GB + large buffer).
FDISK reported no partitions initially, as it should.
Selected 'Create Primary DOS Partition'.
Told it No to using maximum available space.
FDISK scanned the HD and reported only 10,781MB total space available - where did my other 70 Gigs go?
Downloaded latest 'Data Lifeguard' utility, which reported size as 80GB with no errors.
I thought perhaps it might be due to using IDE3 Port (RAID port @ KR7A mobo), so reconfigured to use IDE1. Same problem.
FDISK version used was copied to bootable floppy from Command directory of Win98SE.
Any ideas?
Thanks for your help!
Any ideas?
