My Specs:
EPOX 8K3A with AMD 1600+ XP
ANTEC 300WATT PS
PC2100 256 MEG
WINXP
G3 Ti200
HD Setup:
Primary IDE0: IBM 27GIG HD (MASTER) and CDRW (SLAVE)
Secondary IDE1: WD600ABRTL Western Digital HD (MASTER)
I just upgraded from MSI K7 Pro Motherboard with AMD 700 Tbird to EPOX 8K3A with AMD 1600+ XP. Everything worked great in my old setup.
Using the 40 pin 80-conductor IDE interface cable supplied with the
WD600ABRTL Hard Drive resulted with the BIOS/computer not recognizing it while the IBM and CDRW were recognized during POST. After WINDOWS XP PRO fully loaded, the WD600ABRTL Hard Drive was accessible as a "multi word DMA 2". I figured maybe the BIOS was not recognizing the WD600ABRTL Hard Drive correctly, but then I hooked the WD600ABRTL HD using a different interface cable from the motherboard manufacture (EPOX 8K3A), a ULTRA ATA 100 cable, which at POST/BOOT UP the BIOS / COMPUTER Recognized the WD600ABRTL correctly (ATA100 device) in either Primarly IDE0 or Secondary IDE1.
This leads me to belief that the supplied 40 pin, 80 conductor IDE interface cable supplied with WD600ABRTL Hard Drive is NOT compatible with KT333 Chipset's IDE Interface.
Provided Western Digital's "100% Guaranteed Compatibility", I requested a replacement IDE interface cable that is able to handle ULTRA ATA 100 WD600ABRTL Hard Drive. No rely back yet.
Any suggestions welcome.
ANTEC 300WATT PS
PC2100 256 MEG
WINXP
G3 Ti200
HD Setup:
