- Dec 23, 2013
- 88
- 0
- 0
so... i bought my first WD red around 3 weeks ago...
from reviews i assume it should be quieter than WD green. i never have an internal WD green but i have a couple external 3.5" mybook (which is green? CMIIW), so im familiar with it's seeking sound and the fan-like noise it generates.
on my PC, the WD red when being accessed, even when i just use it to create new folder, or just accessing it to enter some folders, it emits a clack clock clack clock sound really loud like a drum.
it's at least twice or three times louder than wd green seeking noise.
initially i thought it was the drive dying. i tried crystaldisk info, and it's reported good. atm i'm doing the extended test with WD datalifeguard diagnostics, still 2 hours remiaining...
1 thing to note... it's very very quiet when not being accessed at all though. when i just use the SSD and not use the WD red at all, it hardly emits any sound. but as soon as i access it, it's clack clack clack clack clack, like marbles falling to the floor.
i tried gaming with it, and when i stand still in an area with no enemy, then no sound, but when i go to new environment, i assume the drive renders or smthn, then its clack clack clack again.
is this common behavior with WD red?
im going to try RMA the drive though i'm quite concern that the local distributor probably won't accept it because smart test on crystaldiskinfo is showing everything is just fine.
is there any test i should conduct before going to local distributor to RMA it?
