weirdologist
I have 2 36GB(WD360GD) raptors running in RAID1 and it is FAST! BUT, I cannot stand the noise the drive makes when the drive is reading or writing data. The head movement is so loud. I can also hear the whinning noise of the disk spinning but I am not as concerned about that as the chattering noise of the head.
My computer has only one 120mm fan running at reduced speeds because of watercooling. My PSU also has no fan. So the only noise that is being generated right now are my raptors. I am also using HD silencers that completely enclose my HD.
OK so, I have heard that that the 74GB raptors have FDB motors so that the whinning of the disk spinning will be reduced, but what about head movement noise? Say I switched to a different HD completely, what are the noise levels(head movement) of the Seagate 7200rpm compared to to the Raptors. And lastly, other brands to consider?
Switching to other drives will reduce the kind of performance I am getting out of these Raptors but I am willing to sacrifice a little performance if I can get some quietness.
Mike
Mike
