actually if it is a green drive then its rpm is variable (5400-7200), I am not entirely sure as to exactly how it varies the rpm (how much time at 5400,7200 and between) but most benchmarks suggest that the drives preform closer to 7200 then 5400, but definitely slower then pure 7200rpm drives. For an esata drive you would notice the difference (though even with internal sata the new 500gb per plater green drives are about the same as the blue and not that far from the black ones), but on usb2.0 any of these drives should saturate the interface so it shouldn't matter (5400 vs 7200, 320gig platers vs 500, even 64 vs 32 vs 16 megs for cache).
