Finally, 40 minutes later, the ready to report has cleared.All my instances say "ready to report" and "project/update" was 5 minutes ago, no change.
Right, for example "My Contribution" -> "My Contribution History" is showingEach day at 00:00 UTC, Worldcommunitygrid takes a database snapshot, and then starts a statistics run to convert the then current boinc credits and time stats into their permanent record of WCG points, result counts, and CPU times. I suspect that the database snapshot happens reasonably quickly. The statistics run takes some time. I remember that the WCG web pages which are statistics related showed sort of a maintenance-in-progress message for the duration of this run, and it could sometimes last for hours.
Perhaps a way to determine these points in time is when "My Contribution" -> "My Team" -> "Challenge Control Panel" is moving the challenge from "Upcoming Challenges" to "Current Challenges" (then it has started), and when it clears the challenge from "Current Challenges" into the team challenge history as "Past Challenges" (then it has finished). Although, either of these display changes could be deferred from the actual database snapshot.The race starts
sometime around 00:00 UTC on Monday, November 16,The race ends
when WCG have taken the database snapshot.
sometime around 00:00 UTC on Monday, November 23,I don't know of a way to observe these two points in time.
when WCG begins to take the database snapshot.
We will help you on this. Stefan is the expert, but at least I got it working.I am sorry, I take back my thoughts that I had these multiple instances figured out. I have several instances set up, but I am having trouble having more than one running at a time...
Human error is great in this one...
I hope I don't lose any bunkered work!
Like @Markfw said I'm sure somebody here can help. Is it Windows or Linux? If you can explain how you spun up the instances I'm sure somebody here can help diagnose where it might be going wrong.I am sorry, I take back my thoughts that I had these multiple instances figured out. I have several instances set up, but I am having trouble having more than one running at a time...
And why you think they are not working, and how you are tracking their progress.Like @Markfw said I'm sure somebody here can help. Is it Windows or Linux? If you can explain how you spun up the instances I'm sure somebody here can help diagnose where it might be going wrong.
| 1 | TeAm AnandTech | 32,619,300 | 0 | 32,619,300 | 32,619,300 | 0 | 0 | |
| 2 | HardOCP | 3,888,472 | -28,730,828 | 3,888,472 | 3,888,472 | 0 | 0 | |
| 3 | SETI.Germany | 3,503,290 | -385,182 | 3,503,290 | 3,503,290 | 0 | 0 | |
| 4 | The Scottish Boinc Team | 3,080,210 | -423,080 | 3,080,210 | 3,080,210 | 0 |
I guess we need the individual stats to see how we really did. There should be an update yet tonight on Free-DCSeems like you folks were by far the most aggressive in bunkering and in dumping the bunkers.
1 TeAm AnandTech 32,619,300 0 32,619,300 32,619,300 0 0 2 HardOCP 3,888,472 -28,730,828 3,888,472 3,888,472 0 0 3 SETI.Germany 3,503,290 -385,182 3,503,290 3,503,290 0 0 4 The Scottish Boinc Team 3,080,210 -423,080 3,080,210 3,080,210 0
I have identical files for that and remote_hosts, including the same password for all 10 instances. What are you using to control the instances, once they are up ?Based on Stefan's guide here, he pointed to this thread on OVN that I have been trying to follow.
[Guide] Setting up multiple BOINC Instances
www.overclock.net
I think I was not properly adding the new password that is unique to each new batch file? I was using the same "password" from the gui_rpc_auth.cfg file for all new instances. At least in my 4th new instance this password had changed from the original? I may have messed up my 2nd and 3rd instances by using the same password from the 1st instance?
I am trying to recover my 2nd and 3rd instances now.
I was able to reconnect to my 1st instance and upload all.
I am having reconnection problems to the 2nd and 3rd, which were only created to continue to get additional tasks.
If you go into c:\program data\BOINC2 and c:\program data\BOINC3 (or whatever you had named the instance folders) there should be a gui_rpc_auth.cfg file in each that can be opened in notepad and show the password. Worst case scenario if you're having issues with the shortcut to open the new BOINC Manager window you can always go into your existing BOINC manager, Select File --> New BOINC Manager Window and then the hostname would be 127.0.0.1: port (so if following that guide instance 2 is 127.0.0.1:31418) and the password would be in the gui_rpc_auth.cfg file in c:\program data\BOINC2 folder. Instance 3 would be 127.0.0.1:31419 and the password in the gui_rpc_auth.cfg file in c:\program data\BOINC3 folder. Please let me know if that helps at all or if I'm missing where the issue is. I'm working under the theory those instances are already running but you're having issues getting the BOINC manager shortcut to correctly connect to them.Based on Stefan's guide here, he pointed to this thread on OVN that I have been trying to follow.
www.overclock.net
I had a typo in it before, when you go to do instance 3 it should be 127.0.0.1:31419 since the port increments up by 1 for each new instance. I went ahead and edited the previous post so it would be accurate.Thanks Icecold. I'll work on it, before I open another beer and report back![]()
I suppose several European users will start to upload in a few hours from now; it's in the middle of the night here. (I wanted to sleep through it myself, but woke up and went checking if my timed upload had been working right, and what's on in the forum.)Seems like you folks were by far the most aggressive in bunkering and in dumping the bunkers.![]()
