Keysplayr
- Jan 16, 2003
- 21,209
- 50
- 91
Well,to be fair...he could just let one R295X2 beat a TitanZ and admire both the 2nd and the 3rd...^_^
If that makes you both happy?? Ok? Sheesh.
I just picked up this card and wanted to know if someone could recommend a reasonable PSU that could handle this card and my remainder pc load.
Current Build:
Asus Maximus VII Hero Board
Intel Core i7 - 4790K 4.0GHz
12 gb DDR3 Ram
256 GB Intel SSD
1TB WD 7200 Rpm
R9 295X2
Sound Blaster Z
Coolermaster Haf 932 Case
Corsair GS800 V1 -
Samsung U28D590D 4K Monitor
Astro A50 Headphones
http://www.newegg.com/Product/Produc...82E16817139034
That's what i have similar setup to yours, but i run a 3930 @4.1
Current Build:
12 gb DDR3 Ram
256 GB Intel SSD
1TB WD 7200 Rpm
R9 295X2
Sound Blaster Z
Corsair GS800 V1 -
Current Build:
12 gb DDR3 Ram
256 GB Intel SSD
1TB WD 7200 Rpm
R9 295X2
Sound Blaster Z
Corsair GS800 V1 -
The 1050 might even be a little overkill, but depending on future upgrades and other similar unknowns, I'd say a 1KW or higher of a reputable brand would be more than sufficient.
I bet a solid 850W (Corsair AX or Seasonic) would be "enough". Just depends on how much room you want to have to spare.
