I have an antec 300 case so I'm thinking about doing external water cooling.
From my reading I can see that having more fans on the radiator is a great way to lower temps. However I want a quiet water cooling setup and I want it to still be very low in temps.
My thoughts to mitigated this was to add more radiators or bigger radiators from what I read.
When I'm in idle with my Noctua NH-D14, room temp 70F, I have temps around 20c. I would like the water cooling setup equivalent to be 0c. Maybe that isn't realistic with what I want to do? If not then what can I expect? And what would I need to do to achieve that while still being quiet.
I am looking at this setup: http://www.frozencpu.com/products/1...using_Enclosure_CAS-EX10-2.html?tl=g30c83s138
The one thing that I don't like is that each radiator has 3 fans on it. That seems noisy. I don't want to hear my setup. Or at the least, have low rpm quiet fans on it. But what temps can I then expect?
