WB won't fit Card need help ASAP
Indred
OK I have the four screws installed on my water block and I go to drop "not really" it on my WB and it won't seat all the way. It gets in a bind at the very top between the top of the card and the clear plastic off the WB right bellow the Connectors. PLEASE help!!!!!! I have a dremel that I could sand or shave some off the top of the WB but I would rather not. I have the SLI WB's from DD the NV-78's SLI version. And of course the EVGA 7800GT's X 2.
Edit: I just went ahead and used my dremel and sanded it down so it fit. Thanks for all the help.
