Your cross post has been deleted. Please do not do that. Your question, as stated, cannot be answered. You must provide your specific components, OS, and overall setup for starters. It will also help to know how you use your computer, etc.
What software (or utility) you use to speed up a computer depends on what is making it run slow. To use software / utilities that are specific to you problem you need to know what the problem is.
The "We can fix everything" software / utilities will try to repair everything, including stuff that isn't a problem, and may screw up something that is perfectly OK.
As corkyg says, we (and you) need more information about what is actually the problem.
