Way to lock window focus (not just pin to top)?
NoQuarter
1,006
Anyone know of an way to force Windows to maintain focus on a window? I've tried DeskPins which is close to what I'm looking for.. it allows you to designate a window as always on top, but the window can still lose focus.
What I'm looking for is a way to prevent that window from being able to lose focus at all.
EagleKeeper
Discussion Club Moderator<br>Elite Member
Staff member
Oct 30, 2000
42,589
If a window can not lose focus - then you can not do anything else on a Windows system that interacts with the user. That includes any controls/dialog boxes, etc
NoQuarter
1,006
Yea I've discovered this now. Closest I've got to getting where I want is writing up this little script:
Set WshShell = WScript.CreateObject("WScript.Shell")
i=1
Do
WshShell.AppActivate("The Lord of the Rings Online")
WScript.Sleep(130)
i = i + 1
Loop Until i = 200
The 130ms sleep gives the system enough time to process the click in web browser on the 2nd monitor while switching it back to the game so my key presses don't get lost too much. Also had to disable the Foreground lock in registry.
Now I just need a way to enable/disable the script so I can remove the loop counter. Maybe it's easy to turn into a VB app or something I have no idea.
