Way to disable PG on auto load?
AnthroAndStargate
1,350
Does anyone know if there is a way to disable Peer Guardian from running on startup? I only want to use it when I am downloading torrents and have it entirely disabled after that.
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
Check your Login Items to see if its set to autoload on startup.
You can find the Login Items by going to;
1. System Preferences
2. Accounts
3. Login Items Tab
Delete anything you don't want to automatically start with OSX. Clicking the checkmark makes the app hide itself upon launching, but you actually need to select and item and press "-" to keep it from launching.
aphex
Moderator
Jul 19, 2001
38,572
Originally posted by: AnthroAndStargate
That worked perfectly. Thanks Aphex.
If I deleted it from loading it wont auto re-add will it?
nope, it shouldn't unless you tell it to or reinstall.
Glad its all worked out!
