- Mar 11, 2004
- 23,444
- 5,852
- 146
I have a display that was cracked, rendering about the bottom 1/5 of the display unusable (the display functions normally, but full width of the bottom portion has black lines that sometimes kinda jitters with color - I figure I'd just get some black construction paper and cover it as it is nearly perfectly uniform, and looking close you can see a bit of light bleed from where the LCD itself cracked, but otherwise the rest is in great shape looking like it normally does). Since its a 16:10 1920x1200 display, so it already had some extra vertical pixels, and so could potentially still function as a 2nd display for watching video where it'd be doing largely 16:9 or even 2.35:1 content. Doing some Googling it was a mix of hacks and utilities that were intended for other uses (and so much of that stuff you have to be careful with), or recommendations like using the Magnify tool that's built into Windows (which I tried, but couldn't get it working right on that display).
I saw some people show screenshot to some utility in the Nvidia drivers that seemed to do what I want, and some others said Intel's integrated stuff could as well. I'm using an RX 480 with an AMD CPU though. I looked but couldn't find anything, and I tried seeing if I could set a custom resolution or anything like that but it wouldn't work.
Does anyone know what that feature would be called and if its possible in AMD drivers? Ideally it'd let me crop the display to the visible portion, where Windows would then treat that as a display of whatever resolution that ends up being, and I can drag windows to it and fullscreen and it'd only apply it to the visible area (as it is now, it recognizes the full display). Or if there's another utility that you can confirm would accomplish what I want. Ideally something that would save that so I wouldn't have to set it every time I restart or anything.
Also could people with Nvidia card (especially say 1050-1060 level cards) check and see if they can accomplish that in the Nvidia drivers. If nothing else I might would see if I can find someone to swap cards with.
