Way to create a hyperlink to map a network drive?
btcomm22
25
Is there a way to create a hyperlink that would map a network drive that you could send to someone in an email?
KB
5,406
389
You could send them an attachment to do this, like a batch file or vbscript file. Problem is, their email program or spam filter is likely to block it.
MrColin
2,403
On some os's a url like "smb://examplehost/share" could be used. Probably easier to send a http url linking to a batch, vbscript, or powershell script.
Ketchup
14,559
248
Is the email going outside the network? I fail to see how that would work, since the map is relative to the computer it is coming from, and a network link would only work inside that network.
Mushkins
1,631
If you sent them a hyperlink to the explicit address, not the mapped letter, the hyperlink would work. For example if you have a server called Server1 with a shared folder called Cats, a hyperlink to \\Server1\Cats\ will open properly.
I think the OP is actually trying to configure a mapped drive by clicking a hyperlink though, which cannot be done. It would need to be an attached script file of some type or a hyperlink *to* a script file. Even the most basic antivirus and antispam protocols are going to block both.
Best way to map network drives en-masse in a large network is via AD login scripts. For one-offs or home use you're pretty much stuck mapping manually.
Ketchup
14,559
248
I agree.
btcomm22
25
It would be within the network and yes, I want a hyperlink that would map a drive. Too bad there is no way to do this.
Mushkins
1,631
For the small benefit it would give from a user perspective, the potential to use it maliciously would be immense.
The best you're probably going to get is to write the CLI command to map the drive out in the email body and give the user instructions to copy/paste it into cmd.exe and hit enter. But even then spam filters might pick up on CLI syntax and think its malicious.
