Originally posted by: Oifish
Is is at all possible to block certain processes from running? Thanks.
I'm just ocd about processes I guess
I want mdnsresponder.exe to never load. I'm just ocd about processes I guess, and I only want certain processes running.
Either you want Bonjour installed or you don't, it seems silly (IMHO) to install it then cripple it by stopping needed services from running. But if you must, you should be able to set the service to 'disabled' in the SCM.
That's whats weird is that I don't see Bonjour in Add/Remove Programs or in the SCM.
