WAY OT: Need help with Tab Delimited Export formatting
Shuxclams
9,286
15
I know its off topic for DC but some of the best minds come here. I have a db I need to export certian fields to a Tab Delimited file format in a specific order and I can't for the life of me get this right..... anyone have experiance with this? Its a MS SQL db export and import fyi.. That also leads to the next question, who has a MS SQL to MySQL conversion utility or script?
SHUX
bunker
10,572
Have you used DTS yet?
Do you have any programming experience? The easiest thing would be to write something like a perl script to connect to the sql db and pull the records you need then insert them into the MySQL db.
Shuxclams
9,286
15
Also I am not much of a coder, especially with Perl or whatever. I can shell script a little, but code with more evolved languages? HaHaHaHaHa! nope...........:eek:
SHUX
bot2600
2,075
Shux, PM me with more detailed information and I will see what I can do:)
cakin
1,060
depending on the lengths of some fields, you may be better off performing a comma delimited extraction.
Shuxclams
9,286
15
I wash I could but I have a specific import function in the software package that takes a specifically formatted Tab Delimited file. :(
SHUX
bunker
10,572
Is this what your talking about?
Sorry for not gettting back sooner shux. Data Transformation Service is a tool in MS SQL server used for importing/exporting data. It would be very easy to go in through enterprise manager and use the DTS wizard to extract the data you needed into a tab-delimited file.
Ken g6
Moderator
Dec 11, 1999
16,743
4,708
75
SHUX
There's a couple easy solutions to that. For one, you could import the comma-delimited file to Excel, then save it as tab-delimited. Or alternatively you could get GVim, load the file, type ":%s/, */\t/g" (where \t is a tab), and save it.
bot2600
2,075
It looks like I have the DTS worked out Shux, I sent you a PM with a question about the mappings. The only thing I haven't figured out yet is adding the extra cariage returns in the middle of the lines, but that shouldnt be too hard.
Bot
