Wavemaster with Window panel?
QueBert
I know Coolermaster sells a side window panel for the Wavemaster case. But, does anywhere sell the case with the window panel instead of the regular one? I'm thinking about getting the case, and would like to find it with the window.
I've never seen it. I have the case and obviously many would have opted for it with the windowed side panel included.
kind of figured that much, guess I'll just have to drop extra bucks to buy it, oh well.
make your own window! its easy and you can usually get a better acrylic when mkaing your own. often premade windows use acrylic that has some distortion. get a sheet from home depot and it's crystla clear 🙂
I wouldn't DARE try and mod the panel of an expensive case like that on my own. I suck with power tools, and I could see myself ruining the panel, which I don't see replacement ones for sell. hehe. if I wanted to learn to mod, I'd do it on throw away 15 dollar cases.
anyone know of a shop in the OC/IE area that does mod jobs? I only found 1 place online that sells the window panel, and I don't think I even like the look of it, too square and plain. But I'd like to get the case and have a panel custom modded.
Falcon-NW Might be able to help you... They mod that case with a lot of cool things...
I am not sure how you would go about it, but I imagine they might do it for a price..
frozencpu has moded wavemasters with side windows and im pretty sure you can buy them seperatly but they seem a lil overpriced, but its the only place that ive seen with them.
Originally posted by: shady06
the gaming system that compusa advertises has a wavemaster with window
The case alone is about 20$ more then most places (not too bad) and it's the only site I've seen where you can add the window panel. I've checked Newegg and about 15 others with no luck.
Some of the other things they offer look nice, the sound dampening & wire management. Just for kicks I put the Wave Master + Panel + PSU + all the extra modding they offer into my cart. $571 bucks, for a case!
I might order the case + window from there and try to do the sleeving/dampening myself, would be a fun weekend project
*runs off to Google to find tutorial links*
haye 1 more question, I've decided to order the window panel. but I see on CoolerMaster's web site they don't have a clear one. I anted clear, but they just a have a light green and a blue one.
has anyone seen these? I like the Blue, but it looks pretty dark, don't want something that's hard to see inside of.
Hi-
Just got a WaveMaster case, and I love it.
Directron will cut a window hole in a side panel if you send it to them-not cheap-around $30, and then they'll add a side window if you want.
Check it at: www.directron.com
GL!
