I got my hands on a pretty powerful fan (intended as my intake), but the plug on the end of it is different than that which can be accomodated by my MB's 3-prong plug.
The fan I'd like to install is a 12V/4W fan (or, at least I *think* its 4watts).
The connector on the end of the fan has 5 holes in it, but it has only three wires running into it (black, red, and yellow).
I'm assuming that, given these three wires, I can simply hack-off a three-prong connector on one of my other fans.
BUT...my concern is wattage/voltage (again, I'm no electrician, and therefore don't understand/appreciate the real difference between the two).
Assuming my MB has a 3-prong connector available to accomodate an extra fan, and assuming I'm using a 350w power supply, do any of you see any problems with what I'm attempting to do here? And if so, would you recommend another way of doing it or another thing to check? I'd hate to blow-out this fan.
My thanks in advance.
